How to clean Pilot jet on old DT15 1995
Ole V
Hi all
i have taken appart my carb, on my old Dt15 as the throttle dosent work at all, also no reaction on throttle screw.
the engine followed a boat i just purchased.
The carb had a lot of lime ( vaporated fresh water )in the gasoline bulp, in the carb. so i suspect that the pilot area are well clogged.
my problem is that i cannot figure out how to clean it.
The pilot in the gasoline bowl only shown a small brass ball next to the mail nozzle,( not able to remove it) and you can only get a little access if you remove the pilot screw on top of the carb, and use a small plier.
how can i clean the complete pilot run???
best regards
Ole
or let me ask in another way - from where does the pilot pick up the gasoline - does it comes through the small holes in the main nozzle
