Results 1 to 6 of 6
  1. #1
    Default Light Switch Wiring on 1961 Fiberform Runabout
    I took on a project of restoring a family heirloom, an old 16 food Fiberform runabout. It was in really bad condition. floor and transom were completely rotted. The unique compound bend windshield was particularly difficult to get replacement for. Anyway the boat is completely restored and I'm working on final details. Among those details is getting the wiring set up as best it should be. This boat originally had 2 push/pull switches. One turned on the windshield wiper. The other has a 2 stage light switch, which is the focus of this post...
    I believe the first stage is supposed to turn on the stern light (pole). The second stage I think, is supposed to turn on the bow (red and green) light as well as the stern light. Originally for instrumentation, there was just very rough ammeter gauge and even more rough red overtemp light. Since this boat is used a lot, I have installed several additional gauges, which all work nicely and accurately. The issue is that these gauges all have lights. I've wired them up, but the question is which switch setting to connect these to. What is "normal"? I think turning on these gauge lights when the bow and stern lights together, occurs. Is that the way this should be wired?
  2. #2
    Join Date
    Dec 2006
    Location
    Greenfield Me. USA
    Posts
    6,207
    Default Re: Light Switch Wiring on 1961 Fiberform Runabout
    Ayuh,...... Stage 1,....
  3. #3
    OK. Lets say there is stage 0 (OFF), Stage 1 (Stern Light (light pole), and Stage 2 (Bow light(red/green) and stern light).
    I can see uses of the stern light for fishing at night when anchored. That does not require the bow light, just the stern light/light pole. That use does not require gauges, as the motor is off. So gauge lights would not be necessary, would they?
    Stage 2 needs the bow light, stern light and gauges, as this is intended for travelling at night.
    Am I missing or misunderstanding something you said, in your relatively short answer?
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,952
    I think its a matter of personal preference....you could always add a separate switch for the gauge lights...
  5. #5
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    5,043
    When I re-wired my old C-Hawk I installed a fused switch panel on the console that lets me control the lights separately. The simple on-off rocker switches allow me to individually control the bow light, anchor light, gauge lights, cabin lights, spreader lights, cabin fan, bilge pump. You can get those panels in a variety of sizes - typically 4, 6, 8, and 10 rockers. If you do that, get the kind that lights up when it is in the "on" position.
    CHawk 25 DLX
  6. #6
    That is a really good idea! I'd rather be able to individually turn on/off what I need at the time...
    Thank you!
Similar Threads
  1. Honda BF40 - Wiring kill switch and oil light
    By CoryTheCowboy in forum Honda Outboard Forum
    Last Post: 08-16-2019, 03:39 AM
  2. Replies: 10
    Last Post: 08-21-2012, 05:58 PM
  3. 1961 Evinrude Starflite III - Wiring Questions
    By rcornish in forum Johnson Evinrude Outboard Forum
    Last Post: 08-23-2011, 09:55 PM
  4. 1961 jonson 55hp coil wiring
    By pete in forum Archive 2003-2009
    Last Post: 08-18-2003, 09:00 PM
  5. I need a wiring diagram for a 1961 Evinrude outboard
    By Robert Arndt in forum Johnson Evinrude Outboard Archive
    Last Post: 05-04-2003, 09:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
