90 hp efi high pressure fuel issues stumping me
pmoravec
engine serial number 2B044975
Engine will fire when spraying starting fluid into air intake
There’s fuel in the vst and the low pressure fuel pump runs when I turn the key.
The fuel only trickles out the s header valve for the high pressure release
Took the high pressure pump out, connected 12v to it and it didn’t run. Bought a new high pressure fuel pump (non oem) and installed it. Replaced the seal on it as well.
Engine still won’t start. I searched threads on here before posting and see something about a regulator that goes back to the vst. Where is it and how can I check it?
any other ideas?
Thanks for any help. I’ve been working on this and waiting for parts for three weeks now.
I had an issue with my pumps bought aftermarket and they died after 4 times out I’d say the high pressure pump has an issue I had a problem with the regulator too and it just made it have 90psi of fuel pressure if look into that high pressure pump
