engine serial number 2B044975
Engine will fire when spraying starting fluid into air intake
There’s fuel in the vst and the low pressure fuel pump runs when I turn the key.
The fuel only trickles out the s header valve for the high pressure release
Took the high pressure pump out, connected 12v to it and it didn’t run. Bought a new high pressure fuel pump (non oem) and installed it. Replaced the seal on it as well.
Engine still won’t start. I searched threads on here before posting and see something about a regulator that goes back to the vst. Where is it and how can I check it?
any other ideas?
Thanks for any help. I’ve been working on this and waiting for parts for three weeks now.
any other ideas?
