SlaveToMyCats
Hello,
I have a little 3.3HP Mariner Two Stroke engine (2006, OP407599). I normally do just basic servicing (impeller etc).
Recently I found gear-case full of water. I'm pretty sure this is due to fishing line wrecking the seal on the prop shaft. I bought replacement seals (official parts) on eBay and have also reviewed the manual.
The problem for me is that to change the seal I have to remove and replace ball bearing (part no 30-95344). I have a couple of questions about this:-
1) It seems to be a pain to get this bearing in the UK, all the suppliers are US based. Does anyone know the spec of this bearing so I can buy an equivalent item from SKF etc?
2) I don't have any special tools, in fact I've never pulled out a bearing before . Assuming I'm OK to wreck the old bearing and replace, can I do this cheaply with tools off amazon, i.e not the expensive tools listed in the service manual.
Really appreciate any tips!
