Results 1 to 2 of 2
    Thumbs up 1994 Johnson 120hp throttle/shift cable Help
    We have a 1994 Johnson motor on a 19' cajun boat and there seems to be a bracket that holds the shift cable near the helm so that there is not slack. It appears to have come un-crimped. Do I need to buy the anchor cable part 126026 or do I need the boot as well? Also, does anyone know the best way of getting it mounted? (Would we need to take off the shift box or can I get in there and hook it up without all that hassle)
    Default Re: 1994 Johnson 120hp throttle/shift cable Help
    i have the same motor and im looking for pictures of the idle timing screw , the full throttle timing screw and the spark advance adjustment rod hoping of trying to figure out where they are set at i can not get the timing right and looking for pictures so i can try setting them off somone else's to see if i can get it to run
  1. 1994 Force 120 HP throttle cable + idle speed adjustments
    By Chandran in forum Chrysler Force Outboard Forum
    Last Post: 08-23-2016, 09:56 AM
  2. throttle and shift cable issues
    By Blackjack2014 in forum Mercury Mariner Outboard Forum
    Last Post: 09-17-2014, 04:30 PM
  3. Throttle and shift cable replacement
    By richard2009 in forum Johnson Evinrude Outboard Archive
    Last Post: 08-04-2009, 05:17 PM
  4. Shift throttle cable
    By bpiper in forum Mercruiser Sterndrive Archive
    Last Post: 07-29-2009, 09:24 PM
  5. Throttle and shift cable route
    By Scott Poe in forum Outboard motors archive 2000-2004
    Last Post: 01-16-2003, 11:41 PM
