The plug isn't firing at all. It has a white wet residue on it . Cylinder not firing i cant figure out why.
how do you know it’s not firing?
Do a compression test. Post results?
Change the plugs, then test for spark. Post results?
What cyl. is white? The middle one?
Middle cyl. could be the fuel pump is bad and needs a rebuild?
Check the fuel for water?
