Results 1 to 2 of 2
  1. #1
    Default Mercury 8.2 Mag Temerature Fault
    I own a 2017 Baja 26 Outlaw with a Mercury 8.2 Mag 430 HP. I have 60 hours on the engine. I have had temperature faults when it has reached 173 degrees on several occasions. I have had our local mechanic address this. They noted on my maintenance records that they clean the sensors located on the exhaust. I am experiencing this again and cannot get a appointment for 8 weeks or greater. My question is if its an exhaust sensor what kind of issues will arise if I continue operating the boat. It only alarms when running at high RPMs for extended periods.
  2. #2
    Join Date
    May 2010
    Location
    DC Burbs/Maryland Eastern Shore
    Posts
    1,827
    Default Re: Mercury 8.2 Mag Temerature Fault
    Could be that there's insufficient water flow at the higher speed which kicks the exhaust alarm. Is the cooling system in good order? If you continue to run it with the alarm going off, then you'll probably break something. If you can live the life in the slow lane until your appointment then yeh, do that. Keep an eye on the temperature all the time.
    Practicing the ancient art of ren-ching
Similar Threads
  1. 2012 Mercury 40 hp EFI 3 Cylinder Cam Sensor Fault
    By dbieganski in forum Mercury Mariner Outboard Forum
    Last Post: 05-09-2019, 10:33 AM
  2. MERCURY 30/40 EFI 4 Stroke Problem Fault with fuse Nr 4
    By Znord737 in forum Mercury Mariner Outboard Forum
    Last Post: 08-08-2018, 03:33 AM
  3. mercury optimax 90hp system fault no9
    By harbat in forum Mercury Mariner Outboard Forum
    Last Post: 09-17-2017, 02:50 AM
  4. Temerature sensor 89 merc mariner 150
    By hennessea in forum Mercury Mariner Outboard Archive
    Last Post: 07-07-2008, 02:23 PM
  5. It Was All My Fault
    By sturgeon_general in forum Johnson Evinrude Outboard Archive
    Last Post: 10-10-2007, 12:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
