Click for Honda Manuals, Parts and Model Guides!
Results 1 to 7 of 7
  1. #1
    Default Cutting off the anti-ventalation plate ?
    I have 2 x Honda 40hp outboards on a 48' Catamaran. Top speed is 12kn. I want to fit large diameter props to increase power not speed. The existing props don't get enough grip/power in the water to manoeuvre the boat at less than 3kn in the marina when there is a breeze.
    A air of diesel motors can spin a cat and reverse the direction with the engines just ticking over I have to give the outboards a big rev then wait for the effect. Not good enough in a breeze.
    I have 4 blade props, max size. The anti-ventilation pate is the limiting restriction, can I cut it and fabricate one higher.
  2. #2
    Join Date
    Sep 2010
    Posts
    19,546
    Default Re: Cutting off the anti-ventalation plate ?
    Welding may distort / bend the housings.-----Look into extension kits to lower the props.
  3. #3
    I didn't know there was such a thing. Thanks, I'll do that. Or did you mean make one ?
  4. #4
    Join Date
    Sep 2010
    Posts
    19,546
    A company called ----bay manufacturing -------They offer kits.----I do not know if they offer one for your motor.----Easy to look up I think.----Or contact a Honda dealer as they may have something.
  5. #5
    Have you looked into the possibility of lowering the motors down from where they are mounted now?
  6. #6
    Quote Originally Posted by Alan Hicks View Post
    The pops are deep enough they don't move enough water to give me the control I need.
  7. #7
    I guess I was thinking that the deeper they were in the water, the denser the water becomes, which would provide more bite. Maybe not enough to be significant, don't know, but a lot cheaper to try than lowering the prop with an extension kit.
    I doubt seriously they're ever going to compete with a diesel rig though.....
    What size props are you running? Are they designed for commercial boats or maybe a pontoon boat? I know some of the crab boats that are using the 40's and 50's are using props WAY bigger than I've ever seen.
Similar Threads
  1. Broken anti ventilation plate
    By Wick in forum Mercury Mariner Outboard Forum
    Last Post: 02-21-2019, 01:15 PM
  2. 1976 Evinrude 6hp anti cavitation plate broke
    By Peterpd99 in forum Johnson Evinrude Outboard Forum
    Last Post: 10-24-2016, 11:06 PM
  3. Anti siphon ?
    By dhearn0513 in forum Johnson Evinrude Outboard Forum
    Last Post: 12-02-2013, 04:34 PM
  4. Using a manual jackplate and anti-cavitation plate placement.
    By redfishsc in forum General Boat Repair Topics
    Last Post: 02-20-2013, 06:10 PM
  5. Anti Freeze
    By truszip in forum Mercruiser Sterndrive Archive
    Last Post: 10-23-2008, 03:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
