Results 1 to 7 of 7
  1. #1
    Default 1969 Johnson 85hp starter problems?
    I just recently came into possession of a 1969 Johnson 85hp that had been sitting for at least 15 years. It had been stored inside and kept out of the elements thankfully. The motor will barely turn over with the spark plugs in. It turns over fine with the spark plugs out. I have tried replacing the starter as well as cleaning the spots where the starter is bolted to the engine to make sure it had a good ground. I have even tried bypassing the solenoid and connecting the battery straight to the starter. It still barely turns over with the spark plugs in. Oh and I have also tried multiple batteries. Any thoughts on what I should try next? Thanks!
  2. #2
    Default Re: 1969 Johnson 85hp starter problems?
    Start with avoltage drop test. Testing is cheaper than thowing money at it. Check out C.D.I. 's guide on this site.
  3. #3
    Join Date
    Apr 2010
    Posts
    4,833
    You said you replaced the starter. Where did you get that from ??
  4. #4
    Quote Originally Posted by swannyson View Post
    Curious about source of starter also?Also, I never had this problem or read about it on here,but could a blockEd exhaust on the engine cause this since it will turn over with plugs out?
  5. #5
    Join Date
    Sep 2010
    Posts
    19,545
    I would remove the lower unit and see if motor turns over easier then.------Blocked exhaust is not the problem.
  6. #6
    Quote Originally Posted by racerone View Post
    He didnít mention the lower being checked out yet.Thanks for responding about the exhaust idea.Only reason I mentioned that was the 69 skitwin I got last year had the leg full of acorns and pine needles from a mouse or chipmunk climbing up the the exhaust Exit port but not up into the engine.Just spitballing on that one.
  7. #7
    Join Date
    Apr 2010
    Posts
    4,833
    Was this a new starter you put on it or what ????
Similar Threads
  1. 1969 85hp V4 Johnson - No Reverse
    By bonamente in forum Johnson Evinrude Outboard Forum
    Last Post: 07-29-2011, 10:27 PM
  2. 1969 85HP Johnson
    By hondamotorcycleguy in forum Johnson Evinrude Outboard Forum
    Last Post: 02-20-2011, 04:32 PM
  3. 1969 85hp johnson
    By miker in forum Johnson Evinrude Outboard Archive
    Last Post: 11-18-2007, 08:53 PM
  4. Joe Help Please 1969 85HP Johnson Rough IdleStalls
    By Rob vanV in forum Johnson Evinrude Outboard Archive
    Last Post: 06-14-2003, 11:13 AM
  5. 1969 Johnson 85hp Questions
    By Tommy Stover in forum Outboard motors archive 2000-2004
    Last Post: 06-09-2002, 08:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
