MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
    Sep 2003
    New Tripoli, PA, USA!
    16,767
    Default Converting a metric starter to an SAE design
    Mercruiser 5.0 230 hp 1986. Starter is held by two 3/8 UNC body bolts that fit tight in the holes to align the starter.
    New starter is for the later, metric engines and uses slightly larger 10 mm body bolts. This allows the metric starter to move around with the smaller 3/8 bolts.
    The "solution" according to the manufacturer is to use "conversion bolts" that have 10 mm bodies that slim down to a 3/8 UNC thread. Swell, but nobody makes the damn thing (and I spent a long time looking). So...
    Made up for the slop by wrapping the bolts with 5 or 6 layers of aluminum foil tape. This is great stuff with lots of uses. Starter is now solidly located and works great.
    Jeff
    May 2020
    Stokesdale NC
    168
    Default Re: Converting a metric starter to an SAE design
    One other possible way would be to take your 10 mm bolt and cut some 3/8 threads on it with a threading die.
    Sep 2003
    16,767
    Boy, am I ever embarrassed! I meant to post this on the Mercruiser forum and I... Doh!
    Jeff
    May 2020
    Stokesdale NC
    168
    Think about it this way, a good idea is always appropriate, the principal applies here as well. Glad that you got your problem sorted out but keep an eye on those bolts, foil is very soft and things may loosen up with time and use.
  1. Starter gear problems after converting to 12 V Model 620
    By hbr95404 in forum Gray Marine Gas Engine Forum
    Last Post: 07-05-2016, 05:18 AM
  2. metric vs standard tools
    By jartzh in forum Mercury Mariner Outboard Forum
    Last Post: 02-10-2015, 06:12 AM
  3. Metric or Imperial?
    By Laurie Jorgensen in forum Johnson Evinrude Outboard Forum
    Last Post: 01-20-2013, 03:01 PM
  4. Metric or sae
    By ernie1944 in forum Mercury Mariner Outboard Archive
    Last Post: 03-06-2009, 08:01 AM
  5. Converting manual b86 30hp Evenrude to electric start with b88 20 hp Johnson starter
    By martman in forum Johnson Evinrude Outboard Archive
    Last Post: 05-08-2003, 10:18 AM
