Timing on these motors is set at the factory for the life of the motor !-----What is your motor doing / not doing ?
Hi.
The original engine crankshaft was damaged by the splined shaft of the Jet outboard, so I got a short block and swapped everythink over to the new block and rebuilt the Jet outboard.
Every thing had to be reset up.
I copied the settings as best I could for the advance stop, but will not know if it is correct until I get her out on the water and check the WOT advance, thats why I wanted to know what the 2 timing settings were supposed to be.
I have an OMC workshop manual but it is from an 1982 model, so I just wanted to be sure of the settings. I have not been able to find an 1985 copy of the OMC manual.
The 1982 manual says 19 deg +- 1 deg.
At the moment when warmed up it is showing TDC when I have a strobe attached to #1 spark plug at idle, running with a flush on the jet.
Not sure what the timing should be at idle. I do have another manual which covers this engine and If I read it correctly it should be 3-5 ATDC, so not sure what it should be at idle.
I am new to outboards so any help is appreciated.
Cheers
Ian
