Results 1 to 5 of 5
Thread: Milky oil
  1. #1
    Default Milky oil
    so i putchased a thundercraft malibu with an 1984 omc 3.8 litre. It had a blown intake gasket ive repaired that and i need to drain the milky oil in it. I jush realized this damn motor has no oil drain plug, how do i change this oil? Its super thick.
  2. #2
    Join Date
    Dec 2006
    Location
    Greenfield Me. USA
    Posts
    6,039
    Default Re: Milky oil
    Ayuh,...... With an oil sucker, ya pump it out through the dipstick tube,......
  3. #3
    Quote Originally Posted by bondo View Post
    Ive tried that the oil is way to thick will kerosene thin it out enough to start sucking it out?
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,272
    how long has the oil been 'milky'?
    a light bulb in a safety housing, under the oil pan, will help the oil flow better...
  5. #5
    Quote Originally Posted by Cars2u View Post
    Probably only if you disable the ignition and run it on the starter with kero in the pan and Makos idea of light bulb to heat it is good.
    I bought a boat that had a known cracked block by PO and the milky oil that came out the valve covers was like sticky paste. was a MF to get out of the bilge lots of hot water and bon ami ... You don't want to hear this but you may have to pull the engine and drop the pan and valve covers to clean it out. Sounds worse than it is as most engines pull in about an hour if you have a lift.
Similar Threads
  1. Milky oil
    By debpli in forum Mercruiser Sterndrive Forum
    Last Post: 08-27-2013, 07:47 PM
  2. Milky Oil
    By milky_oil in forum Mercruiser Sterndrive Archive
    Last Post: 12-03-2008, 12:47 PM
  3. Milky Oil
    By copeland_sunbird in forum Volvo Penta Gas Archive
    Last Post: 11-25-2008, 11:27 AM
  4. Milky oil in a 30 omc
    By jrod1540 in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-06-2008, 07:52 PM
  5. Milky oil
    By boatn4fun in forum Volvo Penta Gas Archive
    Last Post: 08-19-2006, 11:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
