1987 60 hp johnson with vro
dubbyy
I am trying to disconnect the VRO and run gas oil mix
It says disconnect the two wires coming from VRO tank DONE
Disconnect the 4 wire plug black tan purple grey coming from the VRO
I cannot find this connection
Please help with picture if possible
Thank you
Maybe your VRO pump is an earlier model that did not have a warning module !----Model # of your motor ?----pictures of your pump ?----Was your pump disabled already ?----Can you find where the wiring from the pump plugged into the wiring harness ?----Were the wires cut at the pump ?-----Is there an electronic module on your pump oil side?-----Things for you to look at.
Model # J60TLCUC
The motor is now running on the VRO system
It is original and has never been tampered with
I want to switch to gas oil mix for safety concerns
There is a module on that side but it does not look like the one in the utube video
It has 5 wires not 4
The only that looks similar is coming from the power pac
With 5 wires the VRO was replaced with a newer version.----Powerpack does not plug into the VRO warning module.-----Wires were either cut / hidden or the warning module was never plugged into the harness.----Your friendly local boat shop could help you with this.
