Click for Honda Manuals, Parts and Model Guides!
Results 1 to 4 of 4
  1. #1
    Default Random fuel starvation issue, Honda 250 - bulb?
    So, today in some confused seas, with lots of banging around, I had numerous fuel starvation issues. Each time I checked the primer bulb it had no fuel and if squeezed would collapse and take a long time to uncollapse.
    History:
    2013 Honda 250. Just did an 850 hour service, all new filters, spark plugs, gaskets, etc. Also installed a new Mercury OEM fuel primer bulb. My set up is such:
    fuel line from tank (3/8) goes to a 10 micron Yamaha fuel/water filter. I replaced that recently. After that, a 3/8 line goes to the bulb (Mercury OEM/Quicksilver) and then the line that leaves the bulb is a 5/16 that goes to the Honda.
    When heading out today, before the seas got nasty, I had no issues. Running for a good 30-45 minutes at about 6000 rpms. It was only when things started to get rough and choppy that I'd suddenly experience those sudden losses of power, again like fuel starvation.
    I would stop, check the bulb, wait for a minute, slowly get the bulb hard again, and then head off again. I kept it to around 4000 rpms from this point on, but it seemed like, at random, every 5-15 minutes, it would do it all over again.
    Is it possible my bulb took a dump? Only 2 months old, have used it 4 other times in some even worse conditions, and this is the first time it has done this.
    One other question - on a modern fuel-injected Honda 250, do I really NEED a primer bulb?
  2. #2
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,792
    Default Re: Random fuel starvation issue, Honda 250 - bulb?
    I've been told that all Honda 200/225/250 fuel lines should be 5/16" inside diameter.
    How full was your fuel tank(s)? That is, is there any possibility that you are sucking air into the fuel lines due to rough seas or otherwise? For example, are you sure that the filter seal is tight on the F/W separator filter? Are the fuel line fittings tight and sealed?
    The primer bulb has an internal check valve, which sometimes get stuck. Try bypassing the primer bulb.
    The primer bulb is not likely necessary if the engine is being run often. However, if it sits up for, say, a month or two, I think that pre-priming the fuel system would help to start the engine faster, reduce start-up stalls, and put less strain on the starter and batteries.
    CHawk 25 DLX
  3. #3
    It was the anti-siphon valve. Debris was clogging it and keeping it from staying open at times.
  4. #4
    Join Date
    Sep 2008
    Location
    Posts
    4,792
    Roger that! Glad you found the problem and it was a simple fix.
    What was the source of the debris?
    Why not provide more detail on how you determined that was the issue and what you did to unclog the anti-siphon valve so it can benefit others.
    CHawk 25 DLX
Similar Threads
  1. Fuel starvation issue: 2004 Captains Choice 8.1
    By tyrenta in forum Crusader Marine Engine Forum
    Last Post: 07-09-2018, 07:19 AM
  2. 1993 90hp merc carb fuel starvation issue
    By bmicallef93 in forum Mercury Mariner Outboard Forum
    Last Post: 05-31-2016, 11:02 PM
  3. BF 25A Fuel Line/Bulb Issue?
    By jvwalzak in forum Honda Outboard Forum
    Last Post: 05-26-2015, 09:44 PM
  4. 1998 Honda bf90 fuel starvation at higher rpms
    By gulfcoastsurf in forum Honda Outboard Forum
    Last Post: 08-21-2012, 05:43 PM
  5. Fuel Primer Bulb/fuel pump question on a Honda BF130
    By c-level in forum Honda Outboard Forum
    Last Post: 03-21-2012, 02:19 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
