England419
Hey All,
Hoping to get some help with my 90hp 2 stroke. Just bought the boat and did a full service. Changed mixing tube cause it was soft, changed plugs, wires and boots, new fuel filter and separator, replaced a few fuel lines that were soft, new priming bulb, impeller and a few other small things. Boat ran great for 2 weekends. Ran 3 tanks of fuel out and then Memorial Day it all of a sudden wouldn’t run over 4200rpm WOT(wide open throttle) but runs very smooth. It was running at 5000/5200 the past 2 weekends no problem. It also shutters real bad at a neutral idle and will cut off after about 5/10 seconds of idling. Any suggestions?
Also in a side note, when the RPM’s are low the radio cuts in and out. Not sure if that’s due to the poor idle or something completely different.
