Results 1 to 2 of 2
    Default Johnson remote control cable issues
    Hi Folks
    2000 200HP Johnson. First outing this season - got off the ramp and found the boat would not come out of reverse. After some diagnostics on the engine I took the remote control off and found the “cable anchors” for both the throttle and shifter were broken - these are the two small black plastic barrels that go around the cable and anchor it to the remote control (I can't upload photos for some reason). The cables themselves are in excellent shape, smooth, no binding. The remote control is smooth. I presume 20 years of fatigue. Can I get replacement pieces - I’ve looked around on line and have not found just these plastic pieces. I ordered and tried the SAE replacement metal anchors and they do not fit this style of cable (429 series). I’m afraid the failure of .30 cents of plastic is going to force me to replace the cables. Any thoughts?
    Thanks.
    Sep 2008
    Maryland - USA
    8,471
    Default Re: Johnson remote control cable issues
    I believe you need to make five posts before you can add attachments.
    Many people will post pics to their favorite file sharing site and then add a link to where the pictures are (after making the directory read accessible).
    If the barrels in question are non-adjustable, on the control box end, you will need to get new cables as the barrels are molded onto the cable housing. Due to potential liability concerns, I wouldn't even try to 'repair' them...
  1. Stiff throttle cable in remote control, no fast idle
    By coteno47 in forum Mercury Mariner Outboard Forum
    Last Post: 03-29-2020, 08:10 AM
  2. Remote control issues
    By Terry in Ottawa in forum Johnson Evinrude Outboard Forum
    Last Post: 07-31-2019, 08:35 AM
  3. Shift cable replacement 1990 Johnson 90 hp remote control
    By riopga in forum Johnson Evinrude Outboard Forum
    Last Post: 01-23-2018, 03:22 PM
  4. Johnson Remote Control Compatibility - Can I use a 115hp control with a 70hp control?
    By jimklar in forum Miscellaneous marine engine topics
    Last Post: 06-11-2017, 02:06 PM
  5. Looking for closeup picture of remote control cables on Johnson 88 HP
    By jerryny in forum Johnson Evinrude Outboard Forum
    Last Post: 11-09-2012, 05:20 PM
