Hello All new to the forum so excuse any ignorance.
I have a 1989 Evinrude 120HP on a 16ft bass boat. The engine would not run above 3,000 rpms and the boat would not plane and occasionally would stall.
I replaced the spark plugs, checked engine compression 135 psi on all 4....pulled the main jets in the 4 carbs cleaned all 4 jets, one had a little water and main jet was slightly loose 1/2 turn) so I put everything back together. While running with ear muffs a quick rev above 3,000 rpms still produced a miss like it was dropping 2 cylinders. All 4 carbs appeared to be spraying an equal pattern on a quick rev. What should i look for next? Thanks for any help
