VIPTHELIFESTYLE
Hi Pros,
Thank you in advance for your help. Here is the situation.
Motor: 2013 Honda BF50D EFI
Problem: I see a sheen on the water when I use my tilt/trim and eventually it runs low on fluid and needs to be refilled or it doesn't move - especially in the up direction. I've filled it 2 times now and it lasts about a week. I do see milky stuff come out of the fluid fill when changing it.
Questions:
1. How do I isolate the leak? I think it's either the fill screw o-ring (doubt it), the o-ring on the manual release, or God-forbid (but most likely) the oil seal on the ram (part #64 or #47) here... https://www.boats.net/catalog/honda...-bbej-1100001-to-bbej-1199999/power-trim-tilt
2. If it is #64 or 47, how the heck do you get that off, From what I can tell, the end of the ram is shaped like a "T" and it's welded (that's where the pin goes through) looks like this and the T is welded on. https://www.ebay.com/p/804389600?ii...PUD5DaYD3yEU6XRVBKcW1Vl_E5KrjLphoCq-4QAvD_BwE
How do you get that seal on/off? (From the bottom)?
Thank you in advance,
--jb
Questions:
--jb
