Results 1 to 17 of 17
    Default Alpha 1 leak issues?
    Just bought my first I/O. On inspection, no visible signs of leakage. 189 bumpy trailer trip home, leakage at the lower unit seam and front bolt. First inclination is to just tighten everything. Should I be more concerned?
    After watching some assembly/disassembly videos, no one seems to be using any gaskets/RTV. Does the lower unit simply marry flange to flange?
    I have photos, but can't seem to post them.
    Jun 2006
    Spotswood, NJ, USA
    5,077
    Default Re: Alpha 1 leak issues?
    Find the merc manual before you do damage something
    There is a small flat O ring between the halves , without it it will leak gear oil
    not telling us what you have make it only a guess
    Quote Originally Posted by Bt Doctur View Post
    What info do I need to provide beyond Alpha 1? It looks like there are several coats of paint over the id plate.
    Sep 2008
    Maryland - USA
    8,188
    2X on the quad ring missing being a likely source and getting the correct manual.
    I would also be prudent to get a water pump kit if you know it hasn't been changed lately....
    Quote Originally Posted by makomark View Post
    Is there anything between the two housings? Gasket/RTV?
  6. #6
    Jul 2008
    Northboro, Ma, USA
    5,504
    Based on your questions
    Bring it to a certified Mercruiser repair center.
    RTV..... really.........
    Jack
    Mass.
  7. #7
    Jun 2006
    Spotswood, NJ, USA
    5,077
    the only seal between the unit is a small flat O ring called a "quad seal"
    if you try to substitute anything else it will cost you a new drive
  8. #8
    I wasn't looking for a workaround, just trying to understand it.
    Upon further inspection, the couple of drips where the two casings meet look like they probably got flung there during transit and are not coming from the seam between the cases. It looks like it is coming from the top of the shift shaft.
    For some reason, I still can't upload pics. Here is a link. https://drive.google.com/open?id=13u...K0gbriPWOiLTRy
  9. #9
    Jun 2006
    Spotswood, NJ, USA
    5,077
    either from the top or bottom but its a leak though. lower is the shift shaft bushing ,top maybe the carrier seal
  10. #10
    Jun 2006
    Spotswood, NJ, USA
    5,077
  11. #11
    Jun 2006
    Spotswood, NJ, USA
    5,077
    This is the only seal for the oil passage
    click to enlarge
  12. #12
    Jul 2008
    Northboro, Ma, USA
    5,504
    Quote Originally Posted by DeepIssues View Post
    That drive looks to be in somewhat rough shape. (Salt water)
    All the pictures of parts diagrams wont help.
    Do you have a pressure checker?
    Have you ever worked on a Mercruiser outdrive?
    Do you have any special tools that may be needed to disassemble certain components if need be?
    Do you have a Mercruiser Service Manual for that outdrive?
    If you answer NO to any of these questions...................refer to (A)
    (A). You need to have it professionally looked at and diagnosed. Again, Bring it to a certified Repair shop and have it completely checked out and fixed properly.
    Jack
    Mass.
  13. #13
    click to enlarge
    BT, you've been very helpful, thank you. So, would your thinking be that if they lost the o-ring the oil would move into the cavity and then maybe splash up and over? It took a rough ride from NY to RI. I pulled the drive today and got some additional pics...still can't upload, but here's a link...https://drive.google.com/open?id=1qe...zjGW4JqhhyBcz8 Anything here that makes you think something new?
    There is a little play in the lower shift shaft, maybe 1/4 vertical and a little side to side. Is that normal?
    Thanks again,
    Ken
  14. #14
    Jun 2006
    Spotswood, NJ, USA
    5,077
    vertical play is acceptable side to side is not of the lower units splined shaft. The upper brass shoe will move a bit., When you split the unit did you find that seal?
  15. #15
    The seal between the two casings was in place. There is no seal or remnants of a seal at the upper steering shaft. Also looks like upper drive shaft seal is toast. Iíve added new photos to the prior link. I havenít taken it out yet, but it looks like there is copper sheared where the water outlet goes into top end. Doesnít look like it matches pipe though which looks uniform.
  16. #16
    Jul 2008
    Northboro, Ma, USA
    5,504
    You can ask all the questions you want,
    Your fishing for an answer with nothing but visual trouble shooting. Which will not work.
    There are specific ways to troubleshoot.
    That drive is in rough condition.
    It is clear by your photos.
    Try answering my questions and as I said,
    If you answer no to any of them. You need to bring it to a professional.
    Jack
    Mass.
  17. #17
    Jun 2006
    Spotswood, NJ, USA
    5,077
    Pull the copper tube out of the water pump housing and you will see how it goes together. Its a hand press fit into the upper, .
  1. Pre-alpha oil leak
    By 805HD in forum Mercruiser Sterndrive Forum
    Last Post: 04-04-2018, 10:42 AM
  2. Pre alpha to alpha shift issues
    By Rick Baxter in forum Mercruiser Sterndrive Forum
    Last Post: 05-12-2016, 08:41 AM
  3. Alpha 1 oil leak
    By Pyrate in forum Mercruiser Sterndrive Forum
    Last Post: 07-27-2015, 05:54 AM
  4. Alpha One water leak
    By mike1970 in forum Mercruiser Sterndrive Archive
    Last Post: 06-15-2009, 11:51 AM
  5. Alpha 1 oil leak
    By wellcraftnova230 in forum Mercruiser Sterndrive Archive
    Last Post: 01-16-2007, 09:21 PM
