Results 1 to 2 of 2
    Default V-Drives leaking...
    Acquired a 1985 Tollycraft 30 Sportcruiser a couple of seasons ago. Both original Borg-Warner V-drives leak - although they function fine. I have not figured out where leaks in trans are coming from. The boat is on the hard now for cosmetic and mechanic work that I am doing. I will be removing starboard engine and tearing down short block (heads already checked) to rebuild since low compression cylinders caused from overheating. Can the port transmission leaks be fixed in place or can it be removed without removing engine - certainly restricted access to trans though.
    Thanks in advance for suggestions/recommendations - TONY
    Sep 2008
    Maryland - USA
    8,177
    Default Re: V-Drives leaking...
    Now would be the ideal time to address any issues with the gear, while the engine is out...
  1. Water leaking in/oil leaking out 1995 40HP 4cyl merc.
    By mariner4069 in forum Mercury Mariner Outboard Forum
    Last Post: 07-30-2018, 07:41 PM
  2. What new Drives
    By hordos in forum Volvo Penta Gas Engine Forum
    Last Post: 07-13-2013, 12:33 PM
  3. V drives VS. I/O
    By ibanez540r in forum Crusader Marine Engine Forum
    Last Post: 08-04-2010, 11:59 AM
  4. OSI Drives
    By hvac in forum Volvo Penta Gas Archive
    Last Post: 06-11-2009, 08:35 AM
  5. 92 four winns leaking above the drives
    By T Baumgardner in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-30-2006, 12:16 PM
