Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 6 of 6
Thread: Prop Question
  1. #1
    Default Prop Question
    Ive been seeing different ranges on these and it confusing,, I have a 2002 M115A2 on a 22ft pontoon whats the currect prop size or something that will get me close..
  2. #2
    Join Date
    Mar 2010
    Location
    Hamburg, NY, USA
    Posts
    2,851
    Default Re: Prop Question
    You must use trial and error. You need a tachometer. More oitch slows the motor. Start around 12 pitch. You may have to down to 10 to get proper WOT RPM.
    Paul
    Certified Tohatsu TLDI Technician
    Hamburg, NY USA
  3. #3
    So have a 13.75x15 prop getting 4600 rpms which which direction do I need to go to get 5200-5700 rpms also thinking of going from a 3 blade to a 4
  4. #4
    Join Date
    Mar 2010
    Location
    Hamburg, NY, USA
    Posts
    2,851
    Less pitch is more RPM. Maybe 300 or 400 RPM per inch. Diameter is irrelevant. Changing to 4 blades means going even less pitch.
    Paul
    Hamburg, NY USA
  5. #5
    So got a 14x11 at 5700rpm’s getting 23 mph seeing people getting more I’m confused
  6. #6
    Join Date
    Mar 2010
    Location
    Hamburg, NY, USA
    Posts
    2,851
    Apparently 11 pitch is working for you. More pitch is less RPM.
    Paul
    Hamburg, NY USA
Similar Threads
  1. Prop size question and off shore style prop on a through hub exhaust?
    By H2oallyear in forum Propeller Selection and Replacement
    Last Post: 07-25-2014, 07:07 PM
  2. Prop Question
    By xred in forum Honda Outboard Forum
    Last Post: 07-04-2010, 04:27 PM
  3. Duo prop to single prop question
    By glastron24css92 in forum Volvo Penta Gas Archive
    Last Post: 07-23-2009, 12:39 PM
  4. Prop question
    By dreemon in forum Mercury Mariner Outboard Archive
    Last Post: 11-03-2007, 07:22 PM
  5. PROP QUESTION
    By stewsbs in forum Volvo Penta Gas Archive
    Last Post: 10-04-2007, 11:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
