Results 1 to 3 of 3
  1. #1
    Default No power topside, only below deck in 1985 Celebrity 225V
    Hello,
    I recently acquired a 1985 Celebrity 225V. I installed 2 new batteries and checked that all connections are connected. I have 12v power below deck but absolutely nothing topside - this means the ignition switch and dash. I made that the main circuit breaker was switched on and both batteries have 12.5v each. Is there a mystery breaker or switch that I am not aware of? I looked all over the interwebs for this and can't find anything, including owner or repair manuals for this boat. It has a 5.7l OMC aboard BTW. Thanks.
    Bruce
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,259
    Default Re: No power topside, only below deck in 1985 Celebrity 225V
    The ignition switch harness gets its battery connection from the battery connection at the starter. in that time frame, OMC had one or two fuses in the smaller wires connected to that terminal...I'd start there....
  3. #3
    Quote Originally Posted by makomark View Post
    hi, I figured it out. The previous owner disconnected the cables from the starter. I discovered this when I found out the 50 amp fuse was corroded and noticed the cable on the other end disconnected. I pulled the manifold and riser to see the starter as well as replace them because the water passages are in bad shape, and thatís where I discovered the other wires werenít connected.
Similar Threads
  1. relocate start/house batterys (two) from aft. deck to forth deck.
    By TheBrain in forum Johnson Evinrude Outboard Forum
    Last Post: 08-26-2017, 10:30 PM
  2. 4.3LX Gen+ on a Celebrity 180
    By joaqslam in forum Mercruiser Sterndrive Forum
    Last Post: 03-07-2017, 09:46 AM
  3. 2004 2 stroke 25hp Yamaha noisey topside?
    By guido2 in forum Yamaha Outboard Forum
    Last Post: 06-21-2011, 09:17 PM
  4. 1983 Celebrity 210v w/ Mercruiser 260 - Manual help
    By Caleb Mayer in forum Mercruiser Sterndrive Forum
    Last Post: 06-15-2011, 12:39 PM
  5. Celebrity 200 Bow Rider 1991 350 Magnum
    By gkm24 in forum Mercruiser Sterndrive Archive
    Last Post: 08-26-2007, 01:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
