Results 1 to 7 of 7
  1. #1
    Default Bravo 0ne drive shaft bearing torque (OL 762931)
    I removed the drive shaft bearings on my Bravo one drive shaft and not sure what torque to use. I think I have the old style drive with spacer in between bearings and four slots in face of spacer. I think I supposed to set the nut torque at 70-80 ft lbs. When I do the bearing don't spin very well. Any help would be greatly appreciated.
  2. #2
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    5,951
    Default Re: Bravo 0ne drive shaft bearing torque (OL 762931)
    Are you talking about the input shaft on the upper unit? Are you tightening the nut that holds the bearing stack? You are supposed to set that to a rolling torque. The values are different for a new bearing and a used bearing. No where near 70 lbs.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  3. #3
    Yes I am talking about the 15/16 nut that holds the bearing set on the drive shaft at the top of the drive. Did I damage the bearing by over tightening? I assume that is supposed to be set to 5 inch lbs of rolling resistence?
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,289
    that one sets the preload in the bearing set...3 - 6 in*lbs of rolling resistance for used bearings.
    as far as damage - not likely but only you can tell...if the shaft spins smoothly once the preload is set you are likely to be ok...
  5. #5
    Thank you for the information
  6. #6
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    5,513
    I cant say for Bravo, but what you decsribe did occur for Alpha drives. The ujoint bearing assembly was torqued to 65 ish ft lbs with large spacer and with assemblies with small spacer it went to rolling torque. All Apla one Gen II I believe is rolling also.
    here is the Bravo 1 information from the manual. NO mention of spacer or high torque settings at all.
Name:	Bravo ujojnt bearing preload.jpg
    Jack
    Mass.
  7. #7
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    5,951
    Replace the nut Knock the bearings loose and start over...
    Chris
    Jersey Shore.
Similar Threads
  1. Drive Shaft Bearing-- What to do next?
    By Fuddyduddy in forum Mercury Mariner Outboard Forum
    Last Post: 02-24-2018, 01:39 AM
  2. Bravo 3 drive shaft play
    By Chrisvr6 in forum Mercruiser Sterndrive Forum
    Last Post: 02-19-2018, 05:42 PM
  3. Bravo 1 prop shaft bearing failure
    By Villain lll in forum Mercruiser Sterndrive Forum
    Last Post: 07-11-2014, 02:54 PM
  4. DT25C drive shaft bearing
    By OnTwoWheels in forum Suzuki Outboard Forum
    Last Post: 06-21-2014, 05:13 PM
  5. Need to replace Bravo Drive Shaft Housing
    By etiwandablues in forum Mercruiser Sterndrive Forum
    Last Post: 03-15-2014, 10:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
