Results 1 to 4 of 4
  1. #1
    Default Electric shift throttle control Box
    I have a late 70s/ early 80s omc sterndrive and the switch in my throttle control box is shot and finding the same one is proving to be difficult... especially in Canada. Can I use any electric shift control box instead? Thanks
  2. #2
    Join Date
    Sep 2010
    Posts
    19,501
    Default Re: Electric shift throttle control Box
    Not all electric shift is the same.----Likely your sterndrive is a 1977 or older.----You need a control box that applies 12 volts to the forward magnet for forward gear.----And 12 volts to reverse magnet for reverse.-----How did you test your switch ?---How did failure of the switch occur ?----evinrudeparts.ca-----May be able to help you.----Your location ?
  3. #3
    I'm not sure how it happened. That's how I got it. They had an auxilary switch wired in for forward and reverse. How would I test it? And I am just out side of Vancouver.
    Join Date
    Sep 2010
    Posts
    19,501
    When you operate for FORWARD you should see 12 volts to the green wire.----Neutral is no volts on green or blue.---Reverse should see 12 volts on blue wire.-----If those colours are not there then all bets are off.
Similar Threads
  1. Remote Control, throttle/shift
    By BSchoons62 in forum Mercury Mariner Outboard Forum
    Last Post: 04-05-2017, 08:33 PM
  2. Replies: 2
    Last Post: 09-04-2015, 11:50 PM
  3. Throttle/Shift Control Question
    By 426hemi in forum Boat Steering and Engine Controls
    Last Post: 01-01-2013, 02:06 PM
  4. Chrysler 45 Throttle shift control
    By jbwelker00 in forum Chrysler Force Outboard Archive
    Last Post: 05-30-2008, 09:39 PM
  5. Control Box 65 hp hydro electric shift
    By brent in forum Archive 2003-2009
    Last Post: 03-06-2006, 08:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
