Suzuki DT5 (DT5Y, DT-5, DT-5Y) specs, specifications, manuals?
rwernst
Trying to find info on a DT5Y a neighbor didn't want any more. Seems to be a long shaft (is that the Y suffix? I don't see any references to the Y in any of my searches).
Would love to find a copy of the owner's manual for basic specs, plugs, oil ratio (I'm sure 50:1 would work but think it's designed for 100:1).
Serial number is 00503 - 032258 Seems to be a 1999 or 2000 model, has integral tank as well as connector for external (looks like a Chrysler type connector).
One search says it's the same as the Evinrude E5RECS which has the OMC external fuel connector but haven't verified. If true, I'm guessing Evinrude licensed and rebadged the Suzuki, vs. the other way around.
Any info, suggestions (yes, I've googled... :) etc. would be appreciated. Oh, I did find that apparently the plugs should be or will work fine are the NGK BP6HS gapped to 0.031-0.035
Thanks,
Rich
