I've got an older 2001 Honda Bf115 fuel system has been updated.
Motor is operated in fresh water lakes, about 50 hrs per year, always kept in garage when not in use.
During spring inspection, I noted a slight crack in fuel line at the fuel pump end. The hose was just long enough that I could cut off the bad end and reconnect, however.. I'm considering replacing all the low pressure fuel lines as preventative maintenace.
The shop manual does not give any interval on replacement.
How often should these internal lines be replaced ?
Also, should the high pressure line going to the fuel rail be changed ? ( It seems OK).
