It wasn't taken out of gear, I know that for sure. Basically the series of events that lead up to it. My motor has a hard time staying running but once it gets warmed up, it will go all day. Until it gets warmed up, what it will do is idle fine, then throw it into forward, it will studder then die if not immediately throttling it (sometimes it will die anyway if you even throttle it). We were heading through the back channel and into the channel leading to the Gulf of Mexico. Once I straightened up and made sure via depth finder I was in the channel and no risk of oyster bars, I full throttled it. It ran full throttle for about two minutes and then spuddered once then died. I believe it was small white smoke cloud I saw but can't remember the color 100% but remember a burning smell after the smoke appeared. I tried to pull the gear lever up into neutral out of forward but it was stuck in place. I trolled back toward the safe area of water due to only being on a trolling motor. About an hour later I tried taking it back out of forward and was able to without any resistance. I then tried to start it back up and was able to and cruise with it for a little but I was to afraid of destroying the motor. The only thing that really sticks out that might have gummed up the water vent is seaweed that I passed but even then, I remember looking back to ensure the water was running, which it was. I am stumped with this one. Maybe I will have to take it out on my local lake and try to recreate it.
