Click for Chrysler parts and manuals!
Results 1 to 4 of 4
  1. #1
    Default LM318 Cast Aluminum Oil Pan
    Ok.. I have been told 6, 8 and 9 quarts ..what do you run in yours????? my 1967 Luhrs has LM318 RH engine with a huge looking oil pan that is cast aluminum .... It has a baffel in it and its almost impossible to get all the oil out of it.. Just how much oil is it suppose to hold anyway...The book says 6quarts but looking at it that can't be right...looks way too big to only hold 6 quarts.. . I have found several of them for sale but none of them tell the how much oil they are suppose to hold. I really need the correct information so I can mark the dipstick when I get it back together... thanks in advance..
  2. #2
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    12,129
    Default Re: LM318 Cast Aluminum Oil Pan
    If you are able to physically measure the oil pan's sump area (oil level not interfering with the crankshaft) you can do the math to determine the cubic inch volume.
    You will then convert cu in volume to quarts.
    Keep in mind that an approximate 1.4 quarts will be held in suspension at cruising RPM.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP drives
    "Intellectual growth should commence at birth and cease only at death." Albert Einstein
    Please... no PMs! Post your questions on the forum.
  3. #3
    That is exactly..pretty close to what I did yesterday... used a tape measure to determine depth of the crank into the pan etc.. turns out the oil level is dead on the top of the baffle that is cast into the pan... used a gallon jug to fill to the mark and it was exactly 8 quarts ... now when I get it back together I can mark my dipstick correctly..
  4. #4
    Join Date
    Nov 2005
    Location
    Chi West, IL, USA
    Posts
    867
    An older manual indicates 8 quarts + 1 for filter with engine at a 7 angle
    Free download here....
    http://www.correctcraftfan.com/reference/manuals.asp
    A '70 318 spec lists two pans, 1 a stamped steel 4 quart + 1 for filter
    the second a 6 quart + 1 for filter which does not stipulate "cast" pan
    both at the 7 engine angle
Similar Threads
  1. LM318 Replacement Aluminum Intake Manifold
    By piper468 in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 07-03-2014, 10:36 PM
  2. Is aluminum or cast iron a better intake manifold for marine app?
    By Moe94 in forum Mercruiser Sterndrive Forum
    Last Post: 10-07-2011, 11:11 PM
  3. Aluminum versus Cast Iron
    By bulletine in forum Crusader Marine Engine Forum
    Last Post: 08-07-2010, 10:39 PM
  4. Aluminum or Cast manifolds
    By elgineddie in forum Mercruiser Sterndrive Archive
    Last Post: 09-22-2007, 08:29 PM
  5. Aluminum or Cast Exhaust Manifolds
    By 85CJohn in forum Archive 2003-2009
    Last Post: 03-06-2006, 06:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
