ramon gonzalez
First my apologies for the long first post. i just want get get it all out there to get the best help possible.
good day all, new to the forum, but I've been reading for a long time, this is a great forum, it has helped me with power steering issues, sea water pump selection, and i even changed my PDS bearings and U-Joints just by reading previous post. thanks for that.
to the question, my boat has a gm 5.7L branded as a Volvo penta and it has a 280PT single prop outdrive. now last trip out was 22 miles off the coast of Galveston TX. and back at the boat launch i heard a noise, back at home doing the salt water wash down, i put it in drive and now i hear noise from the upper gear box and the lower as well and the prop is squealing, i removed and no lines have been tangle inside, after some inspections i determined there is water in the outdrive, i believe its shot. so time to upgrade, I've read that the 290DP is a much better option. and I've read that the 280 and the 290's have the same intermediate housing, so i want to swap the 280 for a 290DP according to reading some previous post i can just change the suspension fork from the 280 to the 290 and we can bolt it back up, my current 280 has a 1.61 ratio and again from reading i need a 1.95 ratio for the duo prop. that all sound pretty easy, but after reading some of ricardomarine post on the shimming and pre load or negative something i am terrified of an attempt to do this my self. i am pretty mechanically inclined but this procedure i'm not sure. so the real question is if i remove the lower 290dp leg to replace the suspension fork, do i have to re shim any thing or all the other stuff that Ricardo is very adamant about doing when these uppers and lower unit are separated. i do understand that as it is open to go ahead and replace the o rings and seals. i have a lead on a 290DP C with the props for $400. your help will be greatly, thank you in advance.
