2004 Johnson BRP 175HP model J175PLSRB Fill & Drain Screw Seal0311598 last year about this time I reused the the fill & drain nylon gaskets when Changing lower unit oil, which other than oil injection is the only oil this engine use’s.
Image 2 recent oil doesn’t appear to have water intrusion. note water not being separated.
3.is there a alternative gasket besides marine? Currently looking to spend $.95 each gasket then $4. ship so right at $6.
What do you Guy’s think? Thanks TB
- are you Guy’s getting the replacement rubber seals or continueing on w/ the orginal nylon seals?
