Hi All.....I have a 2015 Monterey 268 SSC with a 350 Bravo 3. The gear lube monitor was empty after recently de-winterizing the boat and replacing the sterndrive lube. Saw dripping on the ground of drive lube oil. Looked up in the drive and found oil coming down the lube hose which goes from the transom to the outdrive. ( I think leaking out of the hose top and dribbling down) Now a couple of questions :
* There appears to be NO CLAMP on the hose up where it goes into the drive--Normal ?
*Is that fitting a brass barb or plastic ? Im afraid of breaking it off if I pull the hose off the fitting.
I was thinking about getting a LONG set of needle noise pliers and puling the hose off of the fitting...cutting a little bit of hose off and re-securing with some permatex and possibly using a small clamp or spring clamp. (The hose rides right next to the bellows but high enough so it should be ok).
I'd like to replace or repair the hose. If I had to I was thinking of trying to repair the hose with a barbed fitting and a couple of clamps, do you think that repair would holdup?
Looking for some advice...some sites people say they have just disabled the lube monitor and will fix during a time when the drive has to come off.
On another note my trim gauge didn't work...found a broken wire near the sensor. Im kind of dumbfounded that Mercruiser hasn't made any advances on having less mechanical parts which move throughout the drive. And its only a 2015 !
Thanks,
Art
Thanks,
Art
