Bigpropsnotops
I recently purchased a 1979 pacemaker wahoo with twin 250a volvos I started the port engine for the first time today on the hose started and ran great. When I was to the back to look at the exhaust for water flow sludgy water was coming out. I immediately shut the engine down and pulled the dipstick and of course milky oil. My first inclination is that the oil cooler has a leaky o ring or corroded tube. Upon further inspection of the engine I found the previous owner had left the exhaust manifold drain plug out. And I ran the engine with it out My first question is can running the engine with that plug out cause water intrusion into the oil system? And if not where would you go from there? Any help is appreciated thanks in advance.
