Hi all
I have a 60hp 2 stroke 3cyl 2 carb clamshell merc. Serial number 09602824
For the last couple of years I have an intermittent problem. Often it starts and runs fine then it drops power, sometimes when putting power on and sometimes when its been running fine at speed for for more than half an hour. Sometimes not at all.
On inspection the top cylinder is not working.
I checked for spark and it's there, changed coil thinking weak spark and no change. Stripped carb and cleaned although it was spotless with no blockages. All this work was done this week with compression checked after last outing.
I am now thinking reeds but have no knowledge or experience of them.
I was told by a merc dealer that reeds are nor not available here in UK but after a Google search I have found various types.
Does anyone know which reeds I need and have any input as to changing them, also any other causes for the problem.
I know this is an old motor but even with the current problem it starts great runs great but unfortunately only on two cylinders
Any help would be much appreciated
Ray
Ray
