bstevenson
I am new here and have searched a lot before making an account.... I cannot not find what I am looking for....
Boat started a few weeks ago...first crank of the spring. Battery was dead, I charged and it cranked right up. Shut it off and continue doing some wiring for new lights, speakers, etc...
Now the boat wont start, wont crank... nothing!
The lights from the dash, alarm test, radio, lights, etc all come on when I turn the switch. I can hear a faint click but nothing actually happens.
Doesn't sound like a dead battery or bad starter.
I am to my wits end with this thing...
Here is what I have done and inspected since searching on multiple sites...
New starter, has 12.6 volts at the connector at the starter.
Tested the starter wire 90 amp fuse- power runs through and OHM test.
replaced slave solenoid on top of the engine.
All three batteries are at 12.5-12.8 volts.
Removed and OHM tested the neutral safety switch.
I have the 50 amp circuit breaker and ignition cylinder on order.
I even removed the 2 new batteries and battery shut off switch, back to the way it was last year and still nothing...
Is there ANY other ideas of what it could be?
Located in North Texas, so the boat doesn't ever see a harsh winter or super cold weather.
