Hello All,
I have a 2011 BF 225 that I have done some significant work to but continue to have issues with a DTC 1 alarm.
Items I have addressed in last 12 months:
1. HP and LP fuel pumps with replacement of all screens/filters
2. O2 sensor
3. Fuel lines and filters
4. Port side power head with all major gaskets and valve adjustments per honda manual
5. Complete VST re-build
7. Spark plugs
8. Vertical shaft bushing
Boat ran well after replacing the port side power head last summer. No alarms. Expected performance. Recently been taking the boat out and getting the DTC 1 alarm going off. I would turn the motor off and re-crank then be good the rest of the day. The alarm became more frequent and now will not go away.
In the last few days I have checked my spark plugs for issues and seen no signs of water intrusion. Tested the O2 sensor with multimeter and all numbers appear appropriate. 7.5-8.5 omhs (within range based on honda manual) and voltage response appropriate to heat application. Taken out the injectors and cleaned. Seem to have equal spray with no obvious issues. No water in fuel.
Only thing that seems out of norm is when I tested the fuel pressure. With the motor idling around 650rpm the fuel pressure is 38psi. I read in the manual it should be between 41-48psi. Is this a big enough difference to cause the alarm and make the engine idle somewhat rough? Honda manual says the fuel pressure regulator could be the issue. Anyone had issues with them in the past?
I feel like I've had nothing but issues with this motor since taking ownership. Any advise is appreciated. If I can't figure this out then I will be taking it to the shop for them to put the computer on and see if there is something else going on vs just replacing the fuel pressure regulator and new 02 sensor.
2. O2 sensor
7. Spark plugs
