Results 1 to 13 of 13
    Default Remove shift cable? Mercruiser 1.7 Alpha one gen two
    Hello.
    I am changing bellows on my alpha one gen two. The boat is produced in 2006.
    But how the heck do I remove the shift cable??Click image for larger version.
ID:	23065Click image for larger version.
    Dec 2006
    Chaumont Bay, N.y., USA
    5,959
    Default Re: Remove shift cable? Mercruiser 1.7 Alpha one gen two
    Ayuh,..... There's supposed to be 2 little square headed screws at the shiny point, near the hole, on the inner end of the cable, in yer 2nd picture,.....
    The black plastic piece needs to come off the inner cable, to allow it to be pulled out through the transom,....
    If yer changin' the bellows, you Should be changin' the lower cable, at the same time,......
    It's also a wear item, 'n why do the job twice,..??.....
    Jun 2006
    Spotswood, NJ, USA
    5,076
    The cable end you show is a control cable end, not the cable for the lower shift cable. It has the brass barrel and the 2 square head screws
    Oh. Guess I should be looking better in the engine compartment then. New day with new opportunities today then.
    Jul 2008
    Northboro, Ma, USA
    5,504
    To do a complete short shift cable replacement in order to replace the cable bellows requires a bit of effort and at least one special tool (very deep six point 9/16" Socket).
    If you do not have confidence to do this it would be better to have someone who does.
    If you feel you can do this and are hell bent on doing it we can help.
    Jack
    Mass.
  6. #6
    Dec 2006
    5,959
    Ayuh,.... With the new replacement cables, the little white plastic tube, on the aft end, Unscrews for installation,......
    So the extra long 9/16" socket is no longer necessary,.....
  7. #7
    Jun 2006
    Spotswood, NJ, USA
    5,076
    Guess the merc mechanics screwed enough up for the production change
  8. #8
    Jun 2006
    Spotswood, NJ, USA
    5,076
    Be sure to watch this a few times before you start wrenching
    https://www.youtube.com/watch?v=PZN-HHuIDPI
  9. #9
    Jul 2008
    Northboro, Ma, USA
    5,504
    Quote Originally Posted by bondo View Post
    Thats nice................................How many posts will be received with shifting problems because the boat owner forgot to reinstall plastic tube or didnt tighten it properly and it loosened up...........Not sure that is a good fix but maybe I will do some this year and find out
    Jack
    Mass.
  10. #10
    Dec 2006
    5,959
    Ayuh,..... I suppose it could be forgotten, but it's finger tight out, 'n finger tight goin' in, as well as nowhere to go, if it backs out,....
    It's a simple idea, 30 years late,....
  11. #11
    Found the right one pulled it out and now I could remove the gimbal house.
    Is there a special way it should be inserted in the boat again, a special route? I didnt have the wire that acted as a snake...
  12. #12
    Jul 2008
    Northboro, Ma, USA
    5,504
    Better to You tube it
    To difficult to explain
    Should have taken pictures!
    Jack
    Mass.
  13. #13
    Jun 2006
    Spotswood, NJ, USA
    5,076
    Better pray you have enough access to where the cable comes into the boat, but not following the you tube about the guide wire you may have a difficult time getting the cable to route correctly.
    Most times the core wire is free from any shop and comes from a control cable, solid SS core.
    Just make sure it`s not accidentally inserted into the coupler,
  1. 84 alpha shift cable
    By dtoole in forum Mercruiser Sterndrive Forum
    Last Post: 08-27-2013, 07:46 PM
  2. Anyone know to remove mercruiser pre-alpha outdrive?
    By jadilla in forum Mercruiser Sterndrive Forum
    Last Post: 03-30-2012, 01:22 PM
  3. installing new shift cable 86 mercruiser alpha drive
    By lime4x4 in forum Mercruiser Sterndrive Forum
    Last Post: 03-30-2012, 08:56 AM
  4. Mercruiser pre alpha lower shift cable
    By mre641999 in forum Mercruiser Sterndrive Archive
    Last Post: 09-15-2009, 06:29 AM
  5. Alpha GEN II Shift shaft seal can I remove
    By hystat in forum Mercruiser Sterndrive Archive
    Last Post: 07-02-2008, 03:28 PM
