Results 1 to 4 of 4
    Question 1968 OMC 120 stern drive high idle on start help please!
    Hello everyone, I have a 1968 arrow glass 120 stern drive with the CUE-16c engine 153 ci dual 2bbl carbs. The problem is it seems like its idling fast at warm up and doesn't taper but just keeps getting higher and higher rpm then I get nervous and shut it down for fear of over doing it. What is the proper idle idle speed on warm up for these old engines with choke disengaged and should I prime the carbs with the main throttle before start up. Thank you for your time!
    Dec 2006
    Chaumont Bay, N.y., USA
    6,015
    Default Re: 1968 OMC 120 stern drive high idle on start help please!
    Ayuh,.... Idle should be 600/ 750 rpms,.....
    'n ya prime the throttle at least once to Wot, to set the auto-choke,.....
    Thank you, I will see if I can get within those marks I appreciate your response!
    Jan 2017
    Salem Oregon
    174
    the carbs may need to be tuned to each other... the slightest bit of mis adjustment can cause your issue... also check to see if the throttle control cable is dragging or otherwise mis-adjusted.
    almost always when a cold engine is started, it will labor a bit to run, and so needs a richer mixture/more fuel to run... as the engine warms, the intake air warms a little and the oil gets thinner, it will run much easier.... if the throttle plates are open slightly too much and cant be closed any further, the rpm will climb as the engine warms and runs easier...
  1. Free clymer shop manual for 1968-1989 volvo stern drive
    By crankbait in forum Volvo Penta Gas Engine Forum
    Last Post: 08-30-2015, 09:31 AM
  2. 1968 OMC stern drive RE: Buick V-6
    By K Cad in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-27-2013, 06:21 AM
  3. 1968 evinrude 85hp lack of rpm high idle
    By stan goff in forum Johnson Evinrude Outboard Archive
    Last Post: 09-13-2008, 09:35 AM
  4. Yamaha stern drive will start sometimes
    By perry386 in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 08-21-2008, 10:38 PM
  5. OMC STERN DRIVE IO STALLING AT HIGH THROTTLE
    By Dan Sollars in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 09-03-2006, 09:34 PM
