How did you determine the weaker spark at higher RPM.----What other trouble shooting has been done.-----Has water pump impeller been replaced ?
Thanks for your input. Does anyone know how the power pack is constructed? If it is one unit providing energy to both coils/cylinders it cant be the issue. If it has 2 separate internal “capacitors” or whatever component is used it could be the issue.This is a strange action, like an internal arcing inside the coil, which can get worse as rpm's increase. Since you replaced the coils we can rule that out. Gotta be in the powerpack, but this is an uncommon symptom.
