I just pulled my LU and replaced the dog clutch and reverse gear, along with a water pump replacement. When I pulled the LU I marked the shift rod so I could reassemble properly. Unfortunately the mark rubbed off. My manual (non Seloc) says to screw it in 9 turns, which I’ve done. I can’t seem to get the shift rod to line up with the linkage. Is there a trick that I’m missing? I pulled the 3 carbs off to try to get better access but it’s a PITA to get at the screw and I can’t get at the shift rod to save my life. Thank you.
