Results 1 to 5 of 5
    Default Exhaust Baffle Question
    Gents,
    Found this circular "baffle" loose and rattling inside the exhaust house when removing the lower unit for water pump replacement. part number 3 in this diagram. https://www.marineengine.com/parts/j...xhaust+Housing The legs on this disk were severely bent keeping if from snapping in (my assumption). Quite oily inside this cavity.
    What does this part do? How is it replaced? How will the motor perform if it's missing? Just purchased this motor so have no personal experience of performance other than the word of the seller. Ran it in barrel prior to purchase and started and idled fine. I'm replacing the water pump due to a "weak" pee hole stream.
    Evinrude J15RCNC. diagrams says this part is only used in the 15hp model.
    Thanks for your thoughts.
    Default Re: Exhaust Baffle Question
    Looking around I found this:
    https://forums.iboats.com/forum/engi...or-plug-baffle
    If it seems reusable I would put it back.
    Thanks so much. That's it exactly. Seems like there wasn't a solution found in that thread. Performance will suffer seems to be the result. Logic would say it increases back pressure in the exhaust. The one I have is definitely NOT usable and it also appears that the housing would need to be removed in order to replace it. That requires a powerhead removal doesn't it? I've got an 86 model 9.9 that has the same hole with NO baffle. It's bent up pretty badly but it seems to have had 3 "legs" that snap through the aluminum hole and catch on the other side. I doubt if it stood "prowd" of the inner surface but can't know for sure.
    Anyone else notice this on the 15hp models? I could certainly come up with a way to plug off the hole from the outside that would likely stay in place but wondering if anyone else has encountered this and devised solution?
    Jun 2013
    Duluth Mn
    2,646
    I think they used it for some15s only. Not sure why. I keep em in place when they are used. Fashion something perhaps to do the same job. Probably not gonna take much creativity.
    Found some pictures of the component and condition I'm describing.
ID:	22995   Click image for larger version.
Name:	Restrictor plug 2.jpg
ID:	22996   Click image for larger version.
Name:	restrictor plug 3.jpg
  1. 1977 70 hp seahorse exhaust baffle
    By dan.1straised in forum Propeller Selection and Replacement
    Last Post: 06-24-2017, 10:56 AM
  2. Torque pressure for exhaust manifold and baffle for 1976 115 hp merc outboard
    By Mark W in forum Mercury Mariner Outboard Forum
    Last Post: 11-15-2016, 07:22 AM
  3. Biffle Baffle
    By wickeral in forum Mercruiser Sterndrive Archive
    Last Post: 12-04-2008, 12:53 PM
  4. Mercruiser exhaust baffle replacement
    By glenn allen in forum Mercruiser Sterndrive Archive
    Last Post: 08-05-2007, 06:59 PM
  5. Can anyone tell me if there is a baffle in my engine
    By 102030 in forum Mercury Mariner Outboard Archive
    Last Post: 06-09-2006, 07:27 PM
