Chris,
I think I found some more interesting information out while testing.
Below is a picture of my service manual and, in pencil, the ohm measurements I was getting.
Today, I found some instruction on a simpler way to test a 3 phase rectifier/regulator. Using my multimeter Diode test setting and checking flow from..........
positive lead (on positive rectifer/reg red wire) to each of the 3 yellow AC leads (from alternator to rectifier/reg)
negative lead (on positive rectifer/reg red wire) to each of the 3 yellow AC leads (from alternator to rectifier/reg)
positive lead (on negative rectifer/reg black wire) to each of the 3 yellow AC leads (from alternator to rectifier/reg)
negative lead (on negative rectifer/reg black wire) to each of the 3 yellow AC leads (from alternator to rectifier/reg)
I show voltage/flow BOTH directions between the negative rectifier/regulator lead and all 3 AC yellow leads.
Also.......I removed the ECU and looked at the back. I can see the tops of 5 capacitors. 4 of them look bulged up, which is consistent with a failed cap from my experience. However, it is hard to tell is they are popped/bulged or maybe the potting compound was thicker on these 5.
Is it possible that the engine would not run because the regulator/rectifier is blown? That the tach and voltage gauge drop off when cranking because power is not being supplied from the regulator/rectifier?
Is it possible that the blown regulator/rectifier killed the ECU?
Did you get the new ECU yet?
