Results 1 to 6 of 6
    Default VP 280 PT Trim Motor Problems
    Hey all!
    Over the months I've been able to get a lot of stuff reworked on my 280 with power trim. Cheers to Ricardo with all of his knowledge.
    I'm stuck with a bad trim motor, its original to the package and has what looks like a prestolite motor, that has an open cap at one end, where the shaft of the armature goes into the pump and oil well assembly.
    Any idea if there's a suitable replacement motor that crosses over to this trim motor assembly? Am I going to have to rewind it? The armature has been repaired so many times that it works only intermittently now.
    Many thanks.
    Mar 2019
    Ottawa Canada
    532
    Default Re: VP 280 PT Trim Motor Problems
    I'm sure there is a replacement motor for it. It may cost too much. Maybe try looking for a used one.
    Mar 2009
    Portland, Oregon,
    11,872
    Unfortunately, the 280 PT OEM parts are no longer available. I'm not able to find a p/n for the entire pump, let alone the motor itself.
    You may be able to retrofit one of the later pumps.
    If the threads are not the same, a good hydraulic hose company may be able to install the correct line fittings onto your hoses.
    https://www.ebay.com/itm/NEW-TRIM-MO...rd!97030!US!-1
    Here is one with a few adapters.
    https://www.ebay.com/itm/NEW-TILT-TR....c100005.m1851
    Portland, Oregon
    I was looking at a couple of these.
    Was hoping it wouldn't come down to a different motor/pump assembly.
    I have a couple calls out for armature winding/parts so I'll have to see where this goes.
    Thanks for the ideas, I'll probably look into the one with the adapters if I can't get anywhere. The sad thing is the rest of the pump/relays, etc are in amazing shape, no corrosion etc..
    Quote Originally Posted by RicardoMarine View Post
    Super good news.
    I did a bunch of research, and found that the trim pump used on the aq280pt variants is common with a lot of mid 70s to early 80s Mercruiser stuff. The motor and reservior was very popular, and the variation was in the pump that bolts to the bottom of the reservior.
    Arco makes a current production replacement, model 6217. They also sell the motor shaft adapter for use in setups that require the longer motor shaft. I found a rebadged one on Amazon for 114$ Keep in mind this is only the motor and reservior assembly, no pump block on the bottom.
    I should be receiving mine by Saturday, and I'll test it out.
  6. #6
    I have everything installed, and wired in. If anyone uses this replacement motor/reservior, make sure to pre tap the screw holes into the housing, it's easy to crack the plastic if the screw is too big.
  1. Johnson trim motor problems
    By Katdaddy in forum Johnson Evinrude Outboard Forum
    Last Post: 04-23-2020, 12:40 PM
  2. Trim Motor Problems
    By bluebass in forum Mercury Mariner Outboard Forum
    Last Post: 06-04-2017, 06:26 PM
  3. Operating AQ270 without trim motor - any problems?
    By DKaiser in forum Volvo Penta Gas Engine Forum
    Last Post: 02-11-2017, 07:45 AM
  4. Power trim motor problems
    By Grahamk in forum Yamaha Outboard Forum
    Last Post: 03-26-2015, 03:33 AM
  5. After installing new arco trim motor, trim gauge only points down
    By bkache in forum Johnson Evinrude Outboard Forum
    Last Post: 07-07-2014, 10:46 AM
