Hi everybody, so I replaced the inlet hose on the bravo three and I had to disconnect the quick disconnect from the engine , my question to you is do I need to replace that O-ring and if I do the same but you know what size the o-ring is because I can’t find it. This is the disconnect between the engine Mounted water pump to the transom. Thank you so much for your help!
