Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 8 of 8
  1. #1
    Join Date
    Mar 2020
    Location
    Spring Hill Florida
    Posts
    6
    Default Nissan 2011 Outboard NSF4C Gas in Oil pan
    Hi my Name is Mike I am new to this forum, I would appreciate any help. I just purchase a sail boat with 2011 Nissan outboard model NSF4C 4hp 4 stroke and found Gas in the Oil when was changing the Oil to get the boat Ready. What could cause this problem, I incline to belive it is an stock carb float, but not sure.
    Thank you much for your help.
  2. #2
    Join Date
    Mar 2010
    Location
    Hamburg, NY, USA
    Posts
    2,798
    Default Re: Nissan 2011 Outboard NSF4C Gas in Oil pan
    Probably flooding or misfiring. How does the motor run?
    Paul
    Certified Tohatsu TLDI Technician
    Hamburg, NY USA
  3. #3
    Join Date
    Mar 2020
    Location
    Spring Hill Florida
    Posts
    6
    Hi Paul, Thank you for your quick reply. Motor doesn't want to start, it feel like it try to. I had replaced the carb, with a new one Upgrade to 6HP. New Fuel filter,
    New spark plug,
    clean the fuel lines, clean internal fuel tank, added new Gas. When I went to change the oil I found lot of Gas mixed with the Oil, in the oil pan. I ask the previous owner and he said the Motor was not winterized this winter, also that it has very few hours on it, motor look brand new to me.
    I do Thank you for your help, I sending some pictures.
Name:	Nemo II Seaward Fox Rear.jpg
ID:	22940Click image for larger version.
Name:	SailBoat Nissan NSF4C outboard 2.jpg
ID:	22941Click image for larger version.
Name:	SailBoat Nissan NSF4C outboard 1.jpg
ID:	22942 It is an small sailboat 18 feet
  4. #4
    Join Date
    Mar 2010
    Location
    Hamburg, NY, USA
    Posts
    2,798
    Diagnose the motor to get it running, then check the rest. Remember that a wet plug is either flooding or no spark; dry is no fuel.
    Paul
    Hamburg, NY USA
  5. #5
    Join Date
    Mar 2020
    Location
    Spring Hill Florida
    Posts
    6
    Thank you Paul, I did check for spark and it is OK. Will try to get it running as soon as I get the Oil. And let you know how it went. Buy the way in the carb there is two hoses side by side, you can see it in the pic. it look like they are not connected anywhere. In the carb diagram are reference by number 43, but it doesn't show where they go. Can you advice please.
  6. #6
    Join Date
    Mar 2010
    Location
    Hamburg, NY, USA
    Posts
    2,798
    They are vents and can route via tubing out the lower cowl. Use 10w-30 oil.
    Paul
    Hamburg, NY USA
  7. #7
    Join Date
    Mar 2020
    Location
    Spring Hill Florida
    Posts
    6
    Thank you Paul, I order the oil 10w - 30 marine grade from Amazon, it will be here by Tuesday. Take care of yourself and family in New York!
    Regards, Mike.
  8. #8
    Join Date
    Mar 2020
    Location
    Spring Hill Florida
    Posts
    6
    Hi Paul, I test the outboard today, it started up in the 3th crank, I am very happy. Stopped using killer switch, crank it up, and perfect. Let it run for a while. stopped same thing. So the carb upgrade to 6hp works perfect! Thank you very much for your guidance, Stay safe.
    Mike Chaple.
Similar Threads
  1. Nissan 2011 NSF4C Gas in Oil
    By Chaple in forum Yamaha Outboard Forum
    Last Post: 03-25-2020, 10:59 PM
  2. 2011 Mercury Outboard 60 Hp Timing Specs
    By patamy123 in forum Mercury Mariner Outboard Forum
    Last Post: 05-05-2019, 03:44 PM
  3. 2011 40hp yamaha 4 stroke efi outboard
    By captainbob1250 in forum Yamaha Outboard Forum
    Last Post: 02-17-2019, 03:58 AM
  4. Nissan 4hp 2011 shift problem.
    By Elkjunkie in forum Nissan Tohatsu Outboard Forum
    Last Post: 01-15-2013, 04:17 PM
  5. My 5 HP 2011 Honda Outboard is not cutting it
    By jmaustin in forum Honda Outboard Forum
    Last Post: 03-14-2012, 06:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
