TLDR: Replacing a Gen IV 454 Carb with Gen VI 502, how do I aspirate if I have choices? Boat is 1991 Bayliner Command Bridge, single engine used casually on intracoastal and Chesapeake tributaries...
Copied post to start newer thread.... I am a few months down the road and I need advice. Since the last update, the Volvo 8.2Gsi fuel injection was set aside as there were problems with the fuel pumps and I want a Mercruiser type set-up. We broke everything down and sent everything to the shop. Now, my Gen VI Engine is now a 502 bored .030 over with new pistons/rings, new rod/main/cam bearings all assembled into a short block ready for the bolt on goodies. Stock Roller Cam was checked out a-ok and re-installed.
This is where I need guidance.
I have a 1996 Mercruiser 502 Magnum EFI system with promising, yet not verified, history. Even though I have a MPI set-up in hand, much of the advice I have been given by reputable builders is to go with an Edelbrock carb set up since wiring to the boat would be simple and the Edelbrock system is reliable. Others have said the MPI would pay for itself in reliability and fuel savings, but since this boat will likely be run moderately and not looking for breakneck speed, I'm not so certain.
Since I am starting with a short block, I am for drawn to the relative simplicity of a carb set-up. The stock Mercruiser 7.4 from 1991 was carb and ran reliably for nearly 30 years, so I am expecting similar longevity.
Assuming the cost from now to install would be similar for MPI and Carb, what route would the group take; Used Mercruiser 502 Magnum MPI with unknown history, or for completely new Edelbrock carb'd set-up?
There would be wiring and installing an electric fuel pump going from Gen 4 to Gen 6, what else am i missing for MPI?
Do the carbureted and MPI 502 variants of the Gen VI use the same roller cam?
New Manifolds, Risers, and Cooling system are on the way. Hoping this can all come together in the next month or so.
What else am I missing?
