Think about somthing.Your wanting to rebuild a power head for a 30year old motor.Do know if the starter works,fuel pump,alternator,ignition,tnt,does it jump gear at 4k does all this work at hi rpm?a 30year old motor is only worth so much running.
Not a VRO or lube problem...if a oil problem the mixture would be lean (oil/fuel ratio) and the crowns would be cleaner and piston would be scuffed 360° not at 12 and 6 as the piston side thrust is at 3 and 12 and that where you would see first signs of oil failure damage. PM me if you need block.
STOP-----Draw a picture of a new piston and the top ring groove.-------Now put the ring in the groove.----------Measure the piston diameter near the piston rings.-----Now look at the amount of wear in the cylinder.------Note-----As the cylinder wears and as the piston and the ring wears things change.------The side clearance in the ring groove increases because of the ANGLE on the top ring.-----Thus the ring starts to hammer the piston groove at say 5500 RPM.
Some 50 years ago my friend's dad asked me------Why should I use really good oil in my 1966 model 100 HP Johnson.----The motor just burns the oil.------That cemented the concept in my mind that folks do not know much about 2 strokes and lubrication on these wonderful 2 stroke engines.
No, it was not likely the culprit. I have seen weed collection on the intake area along with operation in a tilt position.....among other things, causing motor destruction. The impeller can get enough water to itself and prevent melting, but the water supply to the powerhead is inadequate.
Yes a weak impeller will cause overheat at idle..just cause it "pees" don't mean its cooling.This is probably the biggest culprit on 90° motor rectifier failures. Motor is "peeing" but block is not completely full. That's why the v-4s indicator tube should come off exhaust nipple, up and over top of head and down to discharge fitting. NowCan an impeller that looks to be in good condition not function correctly somehow?
