Thanks for the reply. I knew someone would be able to identify this thing. Is there any way to check the pump before dropping the cash on a new motor?That a old Calco unit...… have to send reservoir off to have new motor fitted. Typical rotten wiring and leaks. Hope the pump is good.
http://www.apimarine.com/marine-electrical/johnson-evinrude-calco-trim-motor-172847-1973-79.html
<br>Thanks for the reply. I knew someone would be able to identify this thing. Is there any way to check the pump before dropping the cash on a new motor?<br>That a old Calco unit...… have to send reservoir off to have new motor fitted. Typical rotten wiring and leaks. Hope the pump is good.<br>
<span style="font-family: Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif">http://www.apimarine.com/marine-electrical/johnson-evinrude-calco-trim-motor-172847-1973-79.html</span>
Yes. Wiring is good. Replaced solenoid. Solenoid clicks when switch is activated.Have you checked wiring,solinoid,switch
Good advice.Water sneaks into the motor, just because water does things like that.-----Rusts the top bearing / bushing area.-----That is why I would mount that motor INSIDE the boat !
Yes, I suspected that.The entire harness into motor is degraded and has allowed water intrusion into motor...….see pic.
