I need someone with Mercruiser 7.4 experience. Port engine not running on all cylinders. Here is the history. Had a frozen valve on cylinder 4 had the head machined and new valve guides installed. Reinstalled the head 2,4,6,8 side. Not my first rodeo with this, my boat has had reversion problems in the past. Adjusted valve as per merc manual, Mark IV big block. New manifolds, wires, rotor, cap, plugs oil change, the usual tune up rebuild. Compression test 120 on all 8 cylinders. She started right up after rebuild. Here is were my problem is and im not sure where to go from here. With a timing light she wont even run unless im at 16 Degrees BeforeTDC. In order to make power, When i turn the distributor counter clockwise she runs better moving the time mark well past the markers up toward the water pump but still doesnt run on all cylinders. I check TDC and it lines up on the balancer and piston 1 is all the way up so i assume it is correct. You can pull the wires on cylinder 2 and 5 there is no difference while running. (again i have 120 compression across the board) I have checked my wires 50 times and im getting spark.
I dont know what else to do at this point. I cant get the timing correct and she isn't running on all the cylinders.
HELP HELP HELP!!!!
HELP HELP HELP!!!!
