1997 30 hp 3 cyl. Oil injection pump air purge procedure
cts33
I need to know procedure for removing all air from all oil lines from oil tank thru pump to oil lines to intake ports.
The system does NOT mix the gas and oil going through the carburetor.----------So hook the motor to a supply of 50:1 mix.----Remove the 3 wee hoses at the intake manifold.----Hold those hoses with open end looking at the clouds.----Start the motor.-------When you see oil at the ends of those hoses you plug them into the manifold.----Add clamps later.------Run for 4 -1/2 minutes more then go to straight gas for fuel.
